Hi all,
I have a 2006 Stilo Sporting 1.9 JTD 8V (85K miles). It is currently always displaying the amber engine management light. It has been on for approx 4 weeks and apart from sluggish performance when climbing steep hills it accelerates fine and has no other symptoms such as black smoke from the exhaust.
I took it to a local garage and the mechanic said the engine management code was for the turbo. After looking over the car he believed it may be a faulty sensor. I recently went on a 800 mile round trip and apart from the mentioned lack of power (need to drop down to 4th gear on steep hills to maintain constant speed) the car is running well (70 - 80 mph in 5th no problems). The mechanic advised that it could just need a service it resolve the sluggish performance?? I had all the filters and the oil replaced Sept 13 and I have covered 7k miles since then. I am thinking about putting it into a fiat specialist to have them look over it. Any advice on the following questions would be much appreciated.
If the turbo is on the way out is there a good self test I could carry out?
Approximately how much would a garage charge for a turbo replacement?
If I continue to drive it with the fault and the turbo does fail will this also ruin the engine? And if I don't drive above 3k revs will this reduce the changes of a major failure?
I need to try and minimize costs so if it is just he sensor incorrectly indicating a fault is there a way of hard resetting it such as disconnecting the battery to prove it either way?
Thanks for any advice,
Kev
Kev
