DavidInLundSweden
- Jul 24, 2014
- 3
- 1
Hello,
I´m new to Fiats.
Today I tried replacing the rear brake rotors on a MY 2005 Stilo 5-dr diesel, with no success.
The rotor was rusted stuck onto the hub. (quite common situation) I started tapping it with a light hammer. Still stuck, so I continued with a 16 oz hammer.
The rotor was still stuck to the hub, but the hub got dislodged on the wheel-bearing. This surprised me greatly.
I would have expected the axial movement of the hub on the bearing to be positively restricted, at least well beyond the forces stemming from a 16 oz hammer swung in the confined space in the wheel-well and under the car.
I managed to tap the rotor and hub back into place, and the car seems drivable with due care.
Does anyone know how the hub / wheel-bearing are attached to each other, please? Is it just a friction-press-fit., or is it positively fastened?
(I can´t tell from the parts-catalog drawings, which only show the hub as a unit, supposedly including the wheel-bearing.)
I know it is the hub / wheel-bearing interface that was upset, and not the wheel-bearing / rear axle, because of the wobble of the rotor when spun before I tapped it back into its correct position.
Any advice would be greatly appreciated, thanks.
David
Lund, Sweden
I´m new to Fiats.
David
Lund, Sweden
