SGThirkell
Member
Hi all,
While checking for codes etc after changing ECU on my 2002 1.6 16v (which is running without weird engine faults now thank god) I noticed that the engine (coolant) temp was about 96 degrees C and the (intake I guess) air temp was about 60 degrees C.
The gauge for coolant temp shows mid way so I'm assuming the Stilo runs around this anyway yes? But the air temp bothers me alot more, surely that can't be right? Will the sensor be on it's way out? And what sensor is it if you think it is?
Thanks in advance.
Simon.
Thanks in advance.
Simon.
