Looking for some help with my stilo 03 plate 1.6 16 v, it has started running very poorly and is misfiring on cylinder 1, I checked for codes and got p0300 and p0301, with engine running I unplugged coils 1 by 1 to confirm misfire is on cylinder 1, I then swapped over the coil from cylinder 1 to 2 and misfire was still at 1 so it's not the coil, I then did the same with the spark plug and it's not that either, the spark plug from number 1 was wet with fuel when I removed it so fuel is going in, I checked the resistance of all 4 injectors at the injector multiplug and they are also all giving the same reading, so where do I go from here? Appreciate some help from someone with experience with stilos, thanks.
