Thread Tools
Old 17-06-2014   #1
White smoke on start
Hi all
When I start my 1.9 stilo from cold I get about 10 secs of white smoke along with a rich diesel smell this goes after starting and when it's smoking the engine feels like it's making a purring noise but no change in rpm
Any thoughts?
XB23 is offline Reply With Quote Quote
Old 17-06-2014   #2
paullawton2007 has donated!
Re: White smoke on start
i used to get this on my 2.4 when the heater plugs where naff, im sure it unburnt diesel, dont know if this might be the case? i get the smell on my 1.9 now, when it was a bit cold before i changed the glow plugs, i used to warm them a few times before starting? someone might be able to explain why better.
new set of glow plugs wouldnt do any harm
Paul
CURRENT02 STILO 3DR, 1.9JTD 115BHP, SPORTING KIT, SKY WINDOW, 17" BLACK ALLOYS, EGR FULL BLANK, Cloth Sun Blinds, now with Cruise Control (Alfa stork)
PASTStilo Mutliwagon, 1.9JTD, Aftermarket Cruise Control (Alfa Stalk), Cloth Sun Blinds, GOOD TRUSTY F.I.A.T!
OLDER-03 PUNTO 1.2 ACTIVE SPORTING/ 01 PUNTO 5DR/ 98 SEICENTO 0.9!
paullawton2007 is offline Reply With Quote Quote
Old 17-06-2014   #3
Thanks mate I'll try that - do glow plugs even activate on temps over 3c?
Old 17-06-2014   #4
good question! im sure they would still activate/warm up. i remember reading somewhere it may use the extrenal temp sensor on the drivers wind mirror. ill go an check mine im sure i still get the glow plugs light on the dash on start up.
Old 17-06-2014   #5
Are the glow plugs a big job on the stilo?
On my Ulysses they were a pig of a job
Old 17-06-2014   #6
i bought mine and a garage didnt charge alot to change them.
there one which is a right pain in the ar*e to change it either 2 or 3, id do a check and test them if there faulty but if they were you wuld of got the good old pre-heat fault?
Old 17-06-2014   #7
mhowse has donated!
Glow lamp on dash of mine lights up ,though does appear not to be on as long as in the colder days of winter..
Not had the fun of changing glow plugs yet, if you have a look in the guides section you find some very handy information and tips, for glow plugs some info in link from guides below
http://www.fiatforum.com/stilo-guide...stilo-jtd.html
mhowse is offline Reply With Quote Quote
Old 17-06-2014   #8
Interesting ... Yeah i don't get any fault messages popping up I was hoping maybe dirty injectors?
Old 17-06-2014   #9
Yup my glow plug light comes on isn't the stilo common rail?
Old 17-06-2014   #10
yep its common rail
Old 17-06-2014   #11
fiats = frustration
roy lovelock has donated!
do you have a pre heat warning light up when started that stays on for a while after the car is running?
If the light goes straight out then its not the glow plugs, the stilo will tell you if there is a problem with the plugs, i know as ive changed them and it is a right pig of a job that can easily end up in tears as the plugs are very thin and fragile.
Put some premium diesel in the car, and an additive to give the injectors a good clean, this may solve the problem and is by far the easiest solution
Likes paullawton2007 liked this post
Current:
2006 Peugeot 407 sw 2.0d
2004 Fiat stilo 1.9 jtd dynamic multiwagon
2004 Fiat Stilo 1.6 Dymanic Multiwagon - sold april 2013
2003 Fiat Stilo 1.6 active aircon (with EBD) - Written off 22nd dec 2009
roy lovelock is offline Reply With Quote Quote
Old 17-06-2014   #12
Quote Originally Posted by roy lovelock View Post
Well the light comes on and goes off after a while so think that's all good - Hmm I think I will try that might just fix it you never know
Is the best injector cleaner the red fuel additive, reddex is it?
Old 17-06-2014   #13
fiats = frustration
ive been using that one for years, i get once a year in bulk of ebay.
Premium fuel like optimax work the same way and will put a smile on your face!!
Likes Clivvy liked this post
Current:
Old 17-06-2014   #14
just took the boy to sea cadets, still get my glow plug light on as normal, as said get some Redex, i bought some today 3 in Tesco. Asda once a month has it half price for 2, i have just put 20 of Shell Diesel (wouldnt use nowt else) and a bottle of that redex diesel injector cleaner. i do it once a month. keeps everything clean.
good shout Roy
Old 17-06-2014   #15
Clivvy has donated!
glow plug light being on for longer than a few seconds is no good. essentially it should be on for a few seconds as the plugs heat up - this should happen quickly. Then the light will go out, that's when you start the engine.
If your light is on for a minute or so then you have a plug down maybe more, which means you have unburnt diesel coming out the exhaust which is the white smoke.
As far as I know, its a little pig of a job, but not a nightmare or anything, access is fine, the pig part is being careful not to snap them.
I recently did the plugs on my Terrano 4x4, same symptoms as you (white smoke etc), new plugs, a quick belch of white smoke then all good as the system clears.
I use the EcoMax stuff Roy uses, brilliant stuff. I tend to put in 25ml per half a tank, and a bit more on a long journey where I can give the engine some hard revs to clear the crap.
Clivvy is offline Reply With Quote Quote
Thread Tools
(G) White smoke on start up Acapulco gold Ducato 5 13-11-2012 14:09
(T) white smoke George Doc Ducato 4 26-03-2012 20:27
White smoke please help!!!!! chris1201 Lets Talk FIAT 3 06-02-2010 15:51
(T) White smoke scottq2654 Stilo 17 16-09-2007 09:43
(T) white smoke mincer200 Marea 3 29-11-2005 19:46
