Hi... I have a 2006 1.9multijet sporting. The front suspension is clunking over bumps. A friend said it could be the suspension mounts worn. Any Ideas???
The bushes in the wish arms tend to wear pretty quick on the stilos as do the bushes on the drop links either check them yourself or get a garage to check them they will probably need replacing
drop links go bad too.... i changed mine a while ago and straight away got some bad clunking, drove home, and tighten the drop links up and all was and is still goo
Better to jack car up with front wheels off and go over everything checking for any slight knocking first than just trying to change things with hope of fixing it
