hi I took my air con pipes off when rebuilt the top end after a cam belt failure.
Before this at mot /service, engineer wrote fault code P0560 refridgerant pressure switch fault on receipt.
I took car for an air con recharge and the garage said as the pump did not engage when button was pressed he thought it would not be a good idea to try filling as there was an aircon fault.
Fiat service data says that there is a linear sensor for the compressor coolant circuit and too low or too high pressure signals will disable the aircon system.
My question is- Does this fault code come from this sensor and would it be ok to try refilling the system?
