4 times it cut out on M6 southbound with loose connection on dash ended up coming home on recovery truck so chap said alternator suspect, but removing live off the battery and refit it starts 1.9 jtd (80)
prior to phoning recovery disconnecting + & reconnecting sorted it for a time loose connection warning comes up on dash board but by then engine has cut out.phoned recovery then i left it when recovery looked at it it started first time so crank sensor then? easy job or what? (crank angle sensor?)
Multi Ecu Scan. The download is free but you'll need to buy the
cables from eBay!
Have you tried the car since?
You could always see if there is a forum member close with a copy of MES.
turns out my pc wont run windows 8
Tried? im still using it seems fine no issues since
How long are you driving it for each time now?
When mine went it was as if it was dependent on the engine temperature - drive it for 20 mins until it was warm and then stop.
In regards to windows 8, you shouldn't need it, mines running it on Win 7, it doesn't work on Mac OS though.
