can anyone give me advice on how to change drive shaft (joint) which have started to make noise while turning the wheels. I have stilo 2007 1.6 multiwagon.
For some reason, I cannot use efficently enough the search tool of this web site to find relevant results. Do you know that there should be such quidance materials I am in need of in the database of this site, seen them?
I need to ask some further information now that I have finally time to do the replacement. The quidance materials I got are as such enough, but I was warned by a fellow that there is danger with some cars when you withdraw the driving shaft from the differential in gear box that some differential wheels may drop into the gear box if for some reason they move a bit, for example dut to moving of wheel. Does anyone here know if their is just danger in stilo 2007 multiwagon when driving shaft has been withdrawn from the differential?
Another question related to this is where is the gear box oil draining and filling plugd for for the stilo concerned? - I read many posts realted to this but could not find certainty of the location of them.
