stestilo7110
- Mar 21, 2014
- 98
- 35
How would you know if you have excessive play in your gearbox mounts?
If you're referring to the single mounting on top of the gearbox. It sometimes rattles when worn. The rubber in it can also compress, but the only way to tell if yours has, would be to compare it with a known good one.
If you're referring to the 1 or 2 (depending on engine size) stabiliser bar(s) under the engine, you would normally hear a clonking noise when changing gear and/or accelerating if faulty.
Does the 2.4 have any of these stabiliser bars davren? I think one of mines gone.
Oh...and there's no clucking noise just a rocking motion.
