calummitchell
- Apr 27, 2014
- 3
- 1
Hi all im new to this so please be easy on me,
I am currently driving a 1.9 stilo jtd active aircon (115) 54 reg.
a few weeks ago i lost all gas on my accelerator. I noticed the engine was stuck in a constant low rev as i was able to use clutch control to get through the gears and sit in 5th gear at 40 MPH.
1st gear gives me 8 MPH
2nd gives me 20 MPH
3rd 25 MPH
4th 30
5th 40.
I took it to a garage and the reader said:
P0120 accelerator position sensor (1).
the garage tried clearing the error with no luck.
I replaced the MAP sensor on the car the same day with one from the scrapyard. After replacing i still had the issue.
the next day i took it a run and did a throttle relearn (ignition off, on, idle, off, on) and this seems to have helped. the issue disappeared completely for around 100 miles or so, then came back. however it didnt stay this time. I took it to garage for 2nd tim and they managed to clear the error off the ecu. what I get now is for every 3 or 4 hours of driving i do in total it will happen for about 5 minutes, after which it will go back to normal. I had it back in the garage a third time and they investigated and couldn't find anything wrong. no faults or lights or anything.
Im pulling my hair out on this one as I would like to get the issue fixed. My fiance is a new driver and I dont want her to feel more nervous than she already is. Any help would be greatly appreciated.
Kind Regards,
Calum
2nd gives me 20 MPH
3rd 25 MPH
4th 30
5th 40.
Kind Regards,
Calum
