hi iv looked through a few threads but no luck finding a resolution with my issue, i have a recently acquired stilo 1.2, recently the side lights dont work until the dipped beam is turned on and the main beams dont work at all (no main beam symbol on dash) and the tail lights go out, also when centre interior light is on the left indicator is on, when the light goes off the indicator stops. when you turn on left map light the main beams come on and the central locking operates!
iv removed engine fuse box and stripped down and checked and although there is a small amount of corrosion it still has good readings, i have checked all earth points in the engine bay and they all come back as good, i have disconnected all light units and still happens (without lights actually coming on), iv unplugged the stalk and still have the same issues, iv removed fuses for puddle/ceiling lights and central locking still no change....
this seems like an earth fault but from what!!!
any suggestions would be greatly appreciated.
