Right Guys ,
drove the stilo around from the front of the house to the back , to give it a good clean , washed it , had to move it as i was blocking my neigbours drive , put it back there when he got in , when i came to switch the engine off , took the key out of the Ignition , but the engine carryed on Running ... I found one of my Relays in that Gray box was getting Quite hot so changed that one for a spare one i had made no diffrance ,, Its deffo not water got in to the Gray box .. i hope ... So any suggestions ?
i took the Relay apart and i can stop the car by turning off the ignition then moving the little trigger thing in side the Realy and then the engine stops ) but ive put a "fresh working relay" in and still got the same problem
