Technical Proxy Alignment
Wilby , Northamptonshire
Good Day Peeps :D
I have fitted a new Climate Control Controller out of an Abarth, and since doing this my mileage flashes constantly.
Is there anyone in or near Northamptonshire whom has the necessaries to re-align this for me please?
I can buy you a pint or two in return ;)
Regards
You seen the price of beer. You will be better getting the cables and doing it yourself :) Need to do it myself soon as I have just wrapped my clocks up to get fixed. Its only been about three month on the must do list. Lol
if ever you're passing Huddersfield I will do it for you
Hi!
Did you solve the problem?
I have the same problem on my Stilo Abarth.
I have tryed to do the " Proxy Alinment" with the software FiatEcuScan (payed one) but it dosent work.
Everything else work good in the program.But not the clima alinment.
Hi everyone,
A few months ago i had an issue with my cluster which i've successfully replaced and proxy aligned, however the cluster is now reading a lower figure than the previous MOT reading, i'm out by approximately 1200 miles on the clock (under the previous figure). I'm aware that the figures can be out by around 3% between clock and ECU. Mileage should be around 63k miles.
Is there anyway to find out what's gone wrong? could my old milage be incorrect, and my clocks are now just showing the correct figures?
D.
Mileage is stored in the engine management ECU and in the instrument cluster. The mileage you see on the display is from the cluster. As you have fitted a replacement cluster, it will be showing the mileage stored in the replacement one.
You can adjust the mileage upwards (not downwards) with Mutiecuscan software..
