Hi there. Can someone enlighten me as to the correct type of gearbox oil for a Stilo 1.2 please?
Wikipedia:- Gear Oil said:API GL-4. Oils for various conditions - light to heavy. They contain up to 4.0% effective anti-scuffing additives. Designed for bevel and hypoid gears which have small displacement of axes, the gearboxes of trucks, and axle units. These oils are standard for synchronized gearboxes, especially in Europe, and may also be recommended for non-synchronized gearboxes of US trucks, tractors and buses and for main and other gears of all vehicles. GL-4 oils may also be used in many limited-slip differentials.
API GL-5. Oils for severe conditions. They contain up to 6.5% effective anti-scuffing additives. The general application of oils in this class are for hypoid gears having significant displacement of axes, generally non limited-slip differentials. They are recommended as universal oils to all other units of mechanical transmission (except synchronized gearboxes specifying GL-4). Some GL-5 oils in this class, which have special approval of vehicle manufacturers, can be used in synchronized manual gearboxes
Unfortunately no! That's a nice definition of the differences between GL4 & 5, not which I can use.does this clear it up?
The Fiat workshop manual says 75/80
The Fiat owner's manual says 75/80
Autodata say 75/80
The store says 75/90
I know which one I'd go for.
Because they recommended me that one at the store and I also checked in the Castrol website and they also recommend that one. Could it create a problem if I put the 75w90 in?
You can...but your gearbox won't like it. Gear changes in the winter will be very stiff until the gearbox has warmed through. I know, I tried it and very quickly went back to 75W80.
