Carl Mahon
The Stilo has been banging for years now so I bought rear engine mounts! Recently I removed the bolts, M11, I think from the mounts connecting to the engine. However, when trying to remove the bolts in to the chassis cross-member I needed a piece of pipe to loosen! On top of the cross member I sprayed WD40 in to the recesses and let soak. I then turned anti-clockwise so far then back again many times. The next day I repeated the same with more WD40 but these thick bolts twisted and broke leaving the remains inside! 2 days for nothing. What do I do now? I don't know how much of each bolt is left in situ but both screwed out about 10mm before snapping. If I got new bolts I cannot screw them back in! The two rear mounts were disintegrated. Ironically, none of the local mechanics noticed this when I complained of the rattling/banging noise!
Any help would be welcome but I'm shattered now. May take a few pix tomorrow to show what had happened.
Looking forward to your "fiat'ful advice.
