Become our fan on Facebook
Old 3 Weeks Ago   #1
clutch or cyclinder need help
was stuck in traffic yesterday went to pull off and pedal went to floor you can pick it up and put it down but car wont move but if you put it in gear it moves an inch but the dash goes off and clicks
coiuld this be the slave cylinder and my brake foluid is on inimum let me know guys please need car cheers
hertsstilo1984 is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Re: clutch or cyclinder need help
Yes it most probably is. If you look underneath where the gearbox meets the engine you'll probably find dribbles of clutch fluid. Time for a new clutch and slave. Chances are when the slave went it threw brakefluid onto the clutch assembly I personally wouldnt want to risk not changing it
Rich (Stain)
'02 Stilo, 1.6, Dynamic, Black, 3 door, Full Leather
'99 Coupe, 2.0 20v VIS, Portofino Blue, 2 door, Full Leather
OBD2 Diagnostic Codes
Throttle and MAP Relearn Procedures
richydraper is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
I had same thing not long ago it was the slave cylinder push rod had snapped. turns out its made of plastic. check the slave cylinder mine had a gap between it and the gearbox where the push rod was missing. i replaced mine with one off of a mk2 punto i found in the scrappers as it is the same part. either that or check for a hydraulic leak between master and slave.
davec000 is offline Reply With Quote Quote
(T) cyclinder block/piston rings/rebore? loserscar Cinquecento / Seicento 5 13-02-2013 13:24
(T) Clutch slave cyclinder SGThirkell Multipla 14 09-08-2012 14:14
(Tu) Fiat Punto Mk 2 (2000) Slave Cyclinder won't bleed Luttsy83 Punto (Mk2/2b) 9 16-11-2010 00:23
(T) Uno Turbo, Punto GT Cyclinder Heads!! Coxyboy Punto (Mk1) 0 06-06-2008 21:15
(G) 1000cl cyclinder head sisleyman Panda (Classic) 2 24-12-2005 18:06
