Re: Stilo 1.6 EPS Failure and Constant Stalling
Thank you very much!! Very much so, but what do they mean? How can they be cured? Is the key problem why my remote has inexplicably dtopped working?
U1600 = key not recognised
P0606 = PCM Processor Fault = It basically means that the PCM/ECM (powertrain/engine control module) has detected an internal integrity fault in the PCM.
U1700 = CAN Network NCM - NBC (Engine Management ECU - Body ECU)
U1702 = CAN Network NCM - NGE (Engine Management ECU - Electric Power Steering ECU)
c1013 - PAS control unit fault
HOPE THIS HELPS
