General Airbag light
Oh dear i did it wrong.ive got a airbag light that will not do one and getting fed up now .ive brought seat sensor bypass it went off for 2weeks now its back ive changed the battery because i only had a 55 ah and aparently need a 75ah and airbag light still on.so i no ive got enough power going round the car and the bypass is flashing to say its working.so i just dnt no what else do.as anyone got any ideas.the last thing i want to do is get rid of my baby s.but aint going have much choice at this rate as im fed up with ear ache of other half
Disconnect the battery, leave it for 20 minutes then go and clean all the airbag connections throughout the car. Usual suspects are the orange connections under the two front seats and the ones in the boot for the rear bags or the passanger disable switch connection behind the glovebox (but clean all of them just to be sure). Use some electrical contact cleaner (not WD40!), unclip them, give both sides of the connectors a good spray and time to dry then put it all back together and reconnect the battery. Turn the key on and off two or three times to let it clear the errors.
If its still not working then might be worth plugging MES in to see exactly what is causing the fault
Brill hun thank u ive cleaned under the seat ones but didnt even no there was any in boot or one under glovey thank u
