Hello Guys,
I have a Fiat Stilo 1.6 16v 2002.
Was geting ASR,ESR,Alternative Failure Lose Connection. Random Cutouts at cold start and hot.
Best place to start is the ECU and do a BGA Reballing you can do it at a PC/Laptop Service it;s cheap and takes 30 minutes.
Remember to get it out first and ready cause the laptop guys are not mechanics follow Dracco121 post on easy fix on forum if the pins is not your case 100% is the BGA from the chip, also tell your IT guys that the pins need to be unsolder to access the chip.
But also make sure that you do the D4 thingy and check the battery and alternator 12.x off, 14.x on.
Code:
By Nik Nak
The problem occurs due to the use of lead free solder which cracks unlike the softer solder containing lead
When it cracks it can cause a chip to become dis-connected from the PCB
This is very common in game consoles like PS3 & X-Box where the GPUs get very hot under extreme use
