S steva New member Joined Feb 3, 2014 Messages 2 Points 1 Feb 3, 2014 #1 hi i have 03 stilo 1.6 when reving or pulling out of junctions it seems to dye or cut out sometimes hits a flat spot then takes off coil packs map sensor and throttle have all been change and relean done still the same can any1 help
M Maigretnz Patron member Written 5 guides Joined Mar 31, 2012 Messages 573 Points 170 Location Oamaru Feb 4, 2014 #2 Look for an air leak into the inlet manifold.
OP OP S steva New member Joined Feb 3, 2014 Messages 2 Points 1 Feb 4, 2014 #3 hi thank you my exhaust is blowing from the manifold could this be the problem cheers steve
