Yesturday when I started up the engine on my Abarth I got an unpleasant ticking diesel noise. This was right after a thermostat change (old was stuck open). I know that the battery is bad and I did change timing belt 2 weeks ago, tho it all went OK and I had no noise afterwards. It sounded as the pistons hit the valves, didn't like it at all. Anyway, I hooked the charger up over night and this morning I cleared a faulty engine code (P1653), then I tryed the engine one more time - and guess what? It was gone. Engine running well, took it for a ride and I got nothing? It's running really well and I stareted it serval of times.
What can cause this behavior? If it was timing fault noise wouldn't disappear (and run OK for 2 weeks)? Can a faulty battery do this? Coolant fluid fillup? When I got the car 4 weeks ago it had various engine fault codes, but after charging battery and erasing them it was fine.. But a ticking engine??
I did a recording if anyone want to listen to her?
