Hi all, hope you might be able to help, please google has so far been almost useless..
My driver door lock has half broken - I can just about open it manually with the key from the outside but the from the inside the door handle is completely loose (no resistance from the cable or anything). I'm thinking the cable has broken but not sure.
Anyway, I followed the Punto guide on here to help me get the door card off however my door has an additional silver plate on the inside that I need to get past before I can access the lock. Ive taken off all of the bolts around the outside but it still won't come off. I'm wondering if there is anything else I've missed. There are two small circles that look a bit like rivets - do they need to be drilled out? And I also wanted to check if taking this silver plate off will damage the window motor? As I tried unscrewing that and that still didn't want to move.
Any help would be fab - can provide pics of it if needed is a fiat stilo 1.9 JTD if it makes any difference.
Cheers,
Lana
Cheers,
Lana
