Technical ecu replacement
Hi folks
Looking at a 1.6 stilo which has a probem with suddenly cutting out now and then. Bit of research suggest possibility of ECU needing to be replaced - and I see that these can be purchased in a virginised state plug and play for around £150 - question is, is fitting a reasonably straight forward job for DIY?
Hmm interesting. Must do as it says but once its got all the cars information maybe you cant change it to another car ( why would you want to) You get a warranty so if you think he is legit why not?
