A friend of mine will help me replace the timing belt on my 2004 2.4 abarth this monday, and although he done it a couple of times on his own cars, I'm a little concerned about the risks. I thought about leaving it to a professional but they wan't £700 for it, witch is what I paid for the car - that's not happening!
I know that he uses a technique were he put a mark were the cam and crank are aligned, then just do the switch. My question is what my happend if it's a little off? I have seen threads were people experience bad performance - but can the engine take serious damage? I figure if it's a little of we just deal with it from there? (get the timing right)
From what I understand there're two techniques, and this is the none good one? I'm a little confused cos I have seen a few videos on youtube and in the secound technique they find the top dead center and lock the cam there? and then find a mark on the crank to align with? If so, then you use marks either way so why just not use it on cam too?
By the way, I don't know if it does any difference but cambelt is never changed on this car (4k miles). Also I change all components including water pump.
