Technical Help please!!!!!!!
mikeyc2470
hi I am new to this but here goes,
just bought a stilo 1.2 16v active for my wife the main headlight comes on,but will not go off until you turn off the ignition,
had a friend look at it with a multimeter and he said the relay is powering up but not switching off it is just staying live the car just failed its mot because if this as the main beam is not going off or flashing can anybody help please
i cannot afford to get an auto electrician
Is the main beam icon constantly lit on the dash when the ignition is on? If not does it come on when you pull the stalk to flash someone :confused:
the main beam icon comes on on the dash when you pull the stalk back and goes off when you release the stalk,but the main beam lights on the car stay on until you turn off the ignition..
Hopefully its a sticky relay. Try swapping the main beam relay with the dipped beam relay in the fuse box. If the problem moves to the dipped beam when you do this then it'll be a replacement relay that you require. Will be no more than abou a fiver (y)
have swapped relays but when I swapped them the main beam didn't work at all even though the dash icon lit up!!
aargh changed all relays and fuse box still got same problem think I am gonna take a sledge hammer to the thing!!!!!!!!!!!!!!!!!!!!!!!!
So when Relays are swapped the main beams are still on, not moving to the circuit the other relay is from?
If so then its looking at being a fault with the body computer (n)
thanks for all your input,the car is now at an auto electricians to be looked at.my wife decided it is for the best as I have lost patience with it,6 hours in the rain is enough..
once again thanks for all your assistance with this....
Fingers crossed. Can you let us know what it is when you find out please.
