sswaras
- Aug 3, 2013
- 114
- 26
Hi, hope some of you might have came across the same problem or would know a solution for my problem.
My problem is that the front tyres have uneven wear , which is that the front left tyre wears quicker the the right. The wear is even through the tyre, so the edges and midle looses thread at the same time. I also have a bit of pull to left.
When the tyres ware put on tracking was done.
Tyres ware change due to tracking beeing off. After 1st tracking steering wheel wasint straight so I when back and that was fixed.
But slightly pull to left is still hasn't disappeared and tyre will need to be replaced in 2 month time at this rate.
At the moment I only have 2 suspects that might cause this.
1. Broken spring
2. Link/drop rod needing replacement (unsure about the correct name for the part)
Any ideas and help is very much appreciated.
1. Broken spring
