johnnyboyo
- Jul 25, 2013
- 24
- 13
Hi all. Im looking to install a Raspberry Pi in my Stilo. Its a small computer so I can run a media centre for music and videos and I will also have it running a sat nav. I know how it all connects up but I have a problem that I cannot solve.
Basically for the sound from the Raspberry Pi to work I need to connect it through my radio, but to fit a screen in the Stilo I need a Double din facia kit but its only big enough to fit the screen. I thought about putting the radio behind the facia plate but because its an aftermarket one I needed to connect the red and yellow wire together to get a permanent feed, which means I have to turn it on and off manually. So that means I will need to keep removing the facia plate every time I want to turn it on and off.
I also thought of putting the radio in the glove box but there are not any ISO cables long enough for it to reach that far.
Does anyone know any other way this can be done? If you need me to explain more I will do, this paragraph might be a little hard to understand lol. Thanks
