- May 17, 2009
- 57
- 22
Hi
Happy New Year to you all!
I have just had the cam belt changed (5 years was up but not the mileage) and the garage checked it over, tickover spot on and felt more responsive.
Driving on the motorway however, 5th gear accelerating from 70mph (3.5k revs) the dreaded Engine Fail warning light came on and started beeping.
Obviously this scared me half to death but I called the garage (had it done 200 miles away) and they are adamant they checked everything.
I managed to do another 190 miles and used it yesterday (without errors as not at that speed) and tickover etc is fine.
The garage will take a look at it but I have a couple of questions :-
1. will it do any damage to drive around for 6 weeks even though tickover is fine and isnt misfiring etc.
2. if timing is slightly out, what does it entail to fix it - can it still be done? What would they adjust?
Thanks for your help with this, there are many other cambelt issues and some relating to the 4k revs so it is definitely the cause I believe.
Thanks again
Paul
Thanks again
Paul
