Oh and making sure you put it back properly, I didn't half get some stick off the lads the next day when I had to call the AA out because I hadn't secured the air box to the induct pipe properly isn't that right SweexdomboothvaresecrazyMost Easterly Pandasscout500
You'll be fine buddy it really isn't that bad I was just a numpty and didn't tighten it things back up properly. If you can change a set of brake discs then you'll do this easy enough
standard stuff applies;
allow plenty of time - so you don't rush,
if you remove lots of similar parts label them / make notes so you know where it all goes,
simples.. as I said to gadge while staring at a poorly stilo
