Technical Fiat Stilo 1.8 16v MY 2004 Stalling (Low oil pressure)
italas037
Vilnius
Hello everybody, I have quite common problem with my stilo.
When you're coming to a stop and you clutch in, the engine stalls. This doesn't happen all the time and if the air conditioning is on it happens even rarely.
Also, if You're hard on revs in neutral, revs go down and engine stalls.
Things done so far:
- Throttle body cleaned (also tried another throttle body)
- Throttle body relearn
- New spark plugs
- New lambda after cat sensor
I was wondering, maybe some of You have any other/new suggestions how to solve this problem.
Thanks in advance guys:)
Things done so far:
- New spark plugs
how did you solved the problem?
