Belgrade79
Hi all knowledge people, especially deckshair and yellowstilo.
I'm having this problem for some time now, car cuts out in stop and go situations
sporadicaly when it feel like
And this is most happening while engine is warm and on working temperature.
It happends like this stoping and when clutch in rpm drops under normal 700 to
something like 500 rpm and sometimes it return to 700 and sometimes it just cuts off completely. I can instantly restart car and continue driving.
So far i did following:
1. Rechecked and redone timing belt (so finally got intake pressure on idle in his normal state something about 330 mb on 700 rpm which is normal as i read on this forum) car is little quieter but problem remains
2. Changed crank sensor but problem remains
3. Cleaned whole trottle body several times also done relearn procedures (manual ones ignition on 60 sec ignition off 60 sec ... also done relearn over diagnostic software FES ) problem remains
4. Inspected wires all i could, cleaned D4, cleaned fuse box under hood (it was not dirty at all) problem remains
5. MAP sensor to ECU I seen something strange with its wiring concretly map pin for signal of pressure to ecu pin 31 i havent found circuit there BUT fes is giving normal reading of pressure changing while hitting acc pedal. So my question for this is
Is it possible that diagrams are wrong and MAP pin is not going to pin 31 on ECU B connector?
6. Please give us some advices what to do i'm loosing my hair with this car. I'm afraid to drive my family in it.
