So I got a donor car with asr and I want to put it onto my car witch does not is it easy to do? And any advice on anything I should look out for?
so if i did change the asr/abs pump over and the ecu it would work?this will only work with a proxy alignment with FES or MES because this software actually changes the configuration file inside the bodycomputer - this is crucial as the other nodes adapt their behaviour according to this file after a Proxy alignment.
Other diagnostic equipment like the Fiat Examiner tester can't do this because there is no option to change the configuration file of the bodycomputer.
Of course the correct parts have to be installed to the car (probably just the ASR ABS pump which contains the correct software) .
