I had engine light 2 weeks ago. Diagnostic said its a crankshaft position failure. Repairman just reset the failure. Today morning when I speed up on 5 th gear engine lost power. ESP, ASR, ABS failure and engine light. I donshifted gear on seleespeed but when I got the 1 gear the engine stoped. When I try to ignitiate it makes a sound of electrical motor, display shows no oil and the crankshaft turns around (i see it when i open the oil cap).
I changed belt, water pump and 1 generator belt (repairman siad that generator have 2 belts and he dont find V ribbed belt). Oil and filter is also new.
What do you pros think of it?
Thank you for your thought in advance.
