I've been reading a few threads here, but still don't get it... This one has nice photos, but don't quite understand the procedure: https://www.fiatforum.com/stilo/302657-replacing-rear-bushes-wheel-bearings.html
How do I actually remove the hubs from the rear axle? I've got some rear road rumble, and when changing to winter tires yesterday I could do an inspection... I will have to remove the rear hub, as the bearing on the right side seems dried out - not loose in any way.
But how do I start? I can get the wheel off, the caliper and the brake disc. That's fairy easy, but then it is a big nut, which will be removed. But then what?
How do I get it off?
Special tools?
And how to I get the new one onto the axle again?
Help...
Special tools?
Help...
