i have a problem with the boot light on my Stilo 1.9 JTD (5 doors) ...
the bulb is OK but it wont turn on when the boot is open...
i have checked the voltage on the pins where the bulb is attached with boot open and the voltmeter shows 0V..
also there is no message 'BOOT OPEN' on the board when the boot door is open...
the 'Ind. Boot' option in the MAIN MENU is set ON...
is there a fuse for this two functions???
i could not find it in the manual...i have found only the fuse for the rear power supply, located next to the boot bulb...
and where is located the switch for the boot light? is it located in the boot lock?
thank you,
Filip.
thank you,
Filip.
