Thread Tools
Old 09-09-2013   #1
Cool Syncromesh Help.....s
....Hi All
i have read a lot posts in regards to the Syncromesh in Stilo's but i can't find someone with a similar fault. i have a 04 plate Stilo, 108k on clock, MK2 model.
It crunches into 2nd. IF i Change slowly and smoothly , it won't crunch, and double declutching works fine, But downshifting is the one i haven't mastered yet.
But here is the deal. It goes into 2nd just fine, i have no other issues finding any of the other gears and not once has it popped out of 2nd or any other gear for that matter.
due to work locality i have done 615 miles in it since i bought it and the end of May 2013 and it was crunching when i bought it, hence why i knocked the buyer down to 700
is it worth getting it checked? i've read recon boxes fitted are around 300+ and as i will be lucky to do more than 2-3k in it for the year, i am debating doing it. i have had it serviced, all new pads and discs, new flexi pipe and suspension coils springs, so have spent a bit already.
Thanks for the advice everyone.
Rich
richuk123 is offline Reply With Quote Quote
Old 09-09-2013   #2
Yellow Peril has donated!
Re: Syncromesh Help.....s
In view of the mileage and the fact it is a recent purchase, I would begin by changing the transmission oil. Make sure you use the correct viscosity and a good quality fully synthetic product such as this:
http://www.opieoils.co.uk/p-981-fuch...ion-fluid.aspx
I'm sure this will improve shift quality.
Phil
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive - modded for function over form...
Yellow Peril is offline Reply With Quote Quote
Old 23-09-2013   #3
StiloBoy has donated!
Just a thought! Whats the service interval for transmission oil? Only ask as i'm at 90-odd k miles and never changed mine and I don't get crunching but I do get a bit of slowness of change when the engine is still cold.
Ex- 53 plate, Stilo 3-door, Sassy grey, newly refurbished 17" Claw Alloys, Avon ZV5 tires, 1.2 Active
http://www.fiatforum.com/gallery/data/500/26348.png
StiloBoy is offline Reply With Quote Quote
Old 23-09-2013   #4
Trader Rating: 1
rat20v has donated!
is there how to guide on changing the gear box oil? should do mine really, don't have any problems with it but would like to do it for peace of mind
rat20v is offline Reply With Quote Quote
Old 23-09-2013   #5
Quote Originally Posted by rat20v View Post
Very easy.
Get gearbox warm
Remove filler plug (do this before you drain!)
Remove drain plug
Allow 5-10 mins to drain fully
Replace drain plug
Fill (with good quality synthetic transmission fluid) - until fluid begins to spill out
Replace fill plug
Enjoy smooth changes!
Phil
Yellow Peril
Old 23-09-2013   #6
Trader Rating: 1
rat20v has donated!
ThanKs buddy where is the drain amd fill plug buddy? Is it easy to get to?
Robin
Quote Originally Posted by Yellow Peril View Post
Very easy.
Get gearbox warm
Remove drain plug
Replace drain plug
Replace fill plug
Old 25-09-2013   #7
Back in a 500!
alexGS's Avatar
Trader Rating: 1
alexGS has donated!
New Zealand
There are slight differences between models, but the drain plug is usually under the left driveshaft, the fill plug usually on the front of the gearbox. Both are a recessed hex (need a large Allen key or 1/2" drive socket). Some models have 10mm and some models 12mm hex. On the Abarth it is possible to fill through the dipstick hole at the back of the gearbox, hard to see behind the diff (other models don't have a dipstick).
-Alex
'14 VW Golf 1.4TSi, '08 500 Lounge 1.4 Dualogic, '03 Stilo Abarth Selespeed, '08 G Spyder, '71 850 Coupe in bits...
alexGS is offline Reply With Quote Quote
Thread Tools
(T) Fiat Ducato Gearbox Syncromesh failures ronrumbol Ducato 2 14-06-2010 14:31
