Technical Steering heavier?
Glyfada, Αthens
Either i got to used to the steering on city on the island passages or i think their is a problem with my steering it seems in non city mode it is heavier than usual.
Tried to connect Fiatecuscan to steering column but couldnt then found out i had to bridge pins 1,7,9 but after connecting to it the dashboard would light up with so many faults. i managed to connect to the menu but with all those faults i was hesitant to play around. Also where inside can i check for this specific problem? Is there a relearn of lets say how much power the motor should send?
i have this elm cable
