General MAF unpluged advice
Yes maf will be bypassed reading low and power would be down.
Is it fixable or at least able to tape up with gaffa tape to test?
I wouldnt advise running like that for long though.
Maybe some silicone self amalgamating tape might be permanent seal depending how and where its broke or split.
Otherwise a breakers yard for another pipe?
Just dont leave it with tape on forever, if it comes off and sucks something solid into turbo compressor its goodnight for turbo and possibly engine.
Even a little leak after filter could b letting small particles of dust etc into engine and will wear compressor blades.
A good tape up job should prove its ok (original problem)then fix properly.
Looking for splits on inlet pipe was mentioned in post 14 4 weeks ago is this break new or missed
Also re fuel pressure grandguy , these modern diesels run at around 270-300 bar pressure even on idle , maximum around 1300-1400 bar on the 8v 1600bar for the 8v
I say it often but diagnostic software such as fes/mes is priceless for diy diagnosis.
Where a low maf reading comparative to boost might have been found.
I will put up this diagram of pipe in question so readers have idea.
attachment.php
Pipe 14 from oil breather
Pipe 10 down to vapour trap under airbox
Someone had posted in a catch tank thread, looking closely its shown wrong dotted lines make beleive its fitted to turbo outlet not inlet.
But id think the hose from maf to turbo inlet and the 2 pipes joining it are the same?
Whats different if so?
Right guys major help needed been under the car tonight to see if anything was wrong and i have found that the bolt that holds the oil feed pipe has snapped off how can i get it out oil is going every where
Are you talking this bango feed bolt at the turbo
http://img405.imageshack.us/img405/7851/ya6p.jpg
If so its not going to be that tight in the threads, as it seals on the two copper washers, so if the bolt broke off whats left may come out with a screwdriver or even a knife if it wedges inside it may grip, if you know any local engineering places you need an 'easyout'
The other problem is how did it brake?
Was it running when it broke?
Has any debris from the brake gone into the turbo housing, after that bolt is a very small orifice to restrict oil flow.
Any bits block this hole and turbo will die quickly.
You will need another banjo bolt make sure the threads are the same pitch.
Been looking back for some pics
http://www.alfaowner.com/Forum/attachment.php?attachmentid=146700&d=1340547899
When i ordered bolts off eper numbers i ended up with a bolt wrong length and wrong thread, ended up using old bolt that was supplie with turbo.
Dont turn engine over at all it will be losing pressure and making a mess.
The engine block bolt has a fine mesh screen inside.
When you get a new one make sure its in and clean.
A guy had a problem with that bolt leaking he felt it had damaged threads from overtightning i beleive he managed to get a longer bolt to reach good threads.
Was it your bolt or one off new turbo?
This is the one then
http://img5.imageshack.us/img5/1779/ayxi.jpg
Same type of banjo bolt so shouldnt be tight in threads.
Just try a shallow angle knife so it wedges inside and give it a turn, its parralel thread only went tight by compressing the hose end and copper washers
Now its broke off probably just spin out.
If your taking a chance just replacing this bolt, you can always take turbo drain pipe off and confirm oil is still flowing by cranking with injectors unplugged.
