magpie31
well Just to update had it in the garage today and they have diagnosed that the turbo has gone so need replacing. so now on the hunt for another turbo
well just to update this post i have replaced the turbo this weekend and after a drive for a bit for everything to settle down all things are back to normal. very happy and forgot how well this car pulled. now onto the other issues it never ends with one of these cars
It's just all modern diesels, if you buy a Saab vauxhall and some others they all have fiat engines, I actually left the vag scene because I was sick of problems like these, there's no getting away from it also how do you know the 2nd hand turbo hasn't developed the same problem?
Also, not some thing crazy like intake pipe collapsing under heavy vacuum is it?
kind of agree but i have been a VAG/ford guy for many years and never had any issues other than general wear and tear things only reason for this car was due to the size of the boot just needed the space. no wish i had waited till i had more money and got something else. Don't get me wrong when the car works i love it but just same issue now on and off for 3 months is getting me down.
I would be very surprised if this turbo had the same fault as if it did the 3 turbos this car has eaten in different ways and that is just not right there must be something else making them fail.
Aye, tho i doubt my turbo has failed coz i get good boost up to about 2500rpm, although i dont know enough about the workings of the vvt. Im almost certain i have some sort of air flow leak of sorts, with the soiled pipe and the performance difference after i tampered with it. Ud wanna have a look around yours too see if theres any signs of that. Does anyone know wat importance that engine breather pipe plays? Ie if i were to temporarily join the turbo direct to the airbox without the engine breather pipe and oil trap pipe connected to see if itll pull properly above 3000rpm, would that work??
The actual intake pipe isnt subjected to heavy vacuum tho is it? Heavy air flow just.... Or do u mean the vacuum pipes that control the turbo actuator? Cant see them collapsing tho, dont know enough about it tho i spose, maybe they could
It was another fault from back in the day, Had a problem with a turbo car and it was baffling everyone, until we had it on a rolling road and watched the pipe squeeze it's self together, couldn't belive it but :shrug:
