Right I have now installed Alfa stalk, and all wired up from the stalk to brown connector (D4A), checked and double checked against the pins, and all checked out with multi meter showing I`ve got voltage as each button is activated. however it doesn't work anybody got any suggestions, have checked with FECUscan and I am now getting a brake sensor error code of P0703, which I didn't get before. Have had a read some of the previous post and it mentioned about the brake and clutch pedal, using the software it shows that the clutch is being pressed / released, and the brake sensor the same, however I think it was position 2 on the brake sensor remains OFF, could this be something to do with the problem. Also the post suggests about putting a 12v live feed to AO2, is this in the brown connector where you have just connected the green wire from H7 (resume) connector, or is it from another connector block altogether.
