Styling Upgrading blubs in the Stilo
Wigton Cumbria
I thought that id start a thread in here for people wanting to change bulbs in there stilo and they could look in here and see what bulb they need if thats a good idea??
correct me if im wrong here
Side Lights 501
Dipped beam H7
High beam H7
Fog lights ( dont know)
Indcators (dont know)
Interior map reading lights 501
center interior Lights festoon 31mm one ( i think its 31mm )
number plate Festoon 31 mm ( iirc)
Add more info if you know or ill correct it
Bulb types for all Stilo models are listed in the handbook. ;)
What would be good is a description of the bulbs people are using (headlight, fogs and sidelights) along with a picture showing how they look at night? Time and again I've heard people going out and getting hyped up bulbs only to be let down by their brightness, lifespan, colour or a combination of the three.
Mark
In reality, there are several errors in that table (from memory). The first that jumps out at me is for 3-dr tail lights. They are not W5W as that would be a wedge bulb (A). I think the actual bulbs are type B (bayonet) as it says in the table, and 10W.
Second error is the number plate bulbs, which are a festoon (tubular) bulb, not the wedge bulb it says for saloon models. Then again, what's a saloon model? Mine's a hatch (3-door).
Third error - my Stilo's third brake light uses LEDs, not the 2.3W wedge bulbs the table says (they're used in my Spider and also 156s).
-Alex
