squeakysuspen
- Jul 6, 2013
- 6
- 3
hi. just bought an 04 Stilo for it's looks, did'nt do enough research though did I! any way the sun roof is leaking into the footwell it seem's to be running down the front pillar- because there are water stains on the pillar covering- and then dripping from the underneath of the dash to the right of the fuse compartment. These are the symptoms, my problem is I can't see where the drain tube is on the sunroof, and if it is blocked, why is it staining the pillar, could it have disconnected from the sun roof end. Can any one help . if possible with an accurate diagram
