RonvdSleen
- Jul 30, 2013
- 9
- 1
Hi all ,
sorry if my english isn't that good
i bought a Fiat_stilo_1.9_jtd_80_active since shortly
but im noticed that my Fan on the radiator isn't working..
even if i let the engine run for a long time , it doesn't go on after a time as im used to from other cars ..
the airco doesn't work either ... of course
when i put the ventilation in the car on 0 , and than press the airco on i can hear that the ventilation system is going on
but still no signs of the Fan turning on ... and temperature meter on dashbord says temp. is oke when i drive or when i leave the car running in our driveway
can somebody help me with finding a technical info so i know where to look
such as where can i find the relay that switches the fan on and off , or other sensors and how i can check if the relay is working fine
comment : you can response in Dutch, Deutsch, Englisch
ps: i also have a airbag failure but thats not worrying me i heard it should be some connector under the seat.
whats worrying me is that maybe my moter could overheat .. ! o for i forget ... I HAVE NO WATER LOS !
and the standard radio cd-player is doing strange , sometimes i have no frequency .. than only the CD is working ... and no its not the antenna or cable because with a other radio its working fine , but i like it originally
