Thanks for this information, just looked on e bay and it seems there are many to choose from it also seems that some diagnostics tools have faults can you recommend
a, the software you would use and b, who would you think would be best for the diagnostic tool?
Would this software and diagnostic tool work on my 1.9 diesel as well as my sons 1.8 do you think
Many thanks Dennis
I just wrote something similar on another thread - please see
https://www.fiatforum.com/stilo/330622-stilo-cam-belt-change.html?p=3292857
(a) The software (
MultiECUScan) is an obvious choice, and yes, it will connect to diesel models. See
http://www.multiecuscan.net/SupportedVehiclesList.aspx
It is true that some ELM327 cables are better than others. Some will have problems connecting to the CAN bus modules such as the Stilo body computer.
(b) If you want to play it safe, you could go with the all-inclusive bundle from Gendan that includes registered
MultiECUScan (usually 50EUR), good-quality ELM327 interface as well as a K-line (KKL) interface (for older cars/other systems) and the coloured adapters including the one for airbag ECU connection:
http://www.gendan.co.uk/product_FESPKG.html
There is one possible further adapter to buy - the 3-pin adapter for pre-1996 cars - but otherwise, that bundle is complete.
So, that's the luxurious option, but if you're trying to save funds, you can buy a much cheaper KKL cable such as
http://www.ebay.com/itm/VAG-COM-KKL..._Automotive_Tools&hash=item41755d5e75&vxp=mtr , solder a wire between pin 7 and pin 3 (of the diagnostic plug of the cable), and download the free (unregistered)
MultiECUScan.
One option is £114 and the other option about £5, but be aware that you'll also need an ELM327 cable to do other things, such as service interval resets and proxy alignments. I feel that you can strike a nice balance by buying a cheap KKL cable and a cheap ELM327 cable off eBay, and the coloured adapters from Gendan (to save having to do any soldering). That setup will cost under £40 plus another EUR50 if you decide to get the registered
MultiECUScan separately.
Compared to 'scan tools' and other diagnostic package subscriptions, the £114 option is a bargain anyway.
Hope that's cleared it up?
-Alex
