In preparation for fitting the 1.4 lump I got recently, I decided to try swapping the 1.2 wiring out in place of the 1.4s to see if it would run with the 1.2 ecu, having the same ecu pin configuration I didn't see the harm in trying it...
My 1.2 had bodged cruise control wiring into the ecu connector, I had to remove this to get the rest of the loom out. However, I have accidentally de-soldered a couple of the other ecu wires! I switched the ignition on to see what would come up and I got no reading on the temp gauge us the red light was constantly on, I have ASR and car security failure :/
But I didn't think much of it, I'm swapping the looms so it'll be back to normal I thought? Well I just finished swapping the 1.4 loom in (straight swap bar swapping in the 1.4 crank and cam sensors so the connected to the loom) but I'm still getting the same messages - ASR and car security fault
The car is dead, everything else electrical works apart from the engine starting, not even the throttle body will move if I press the gas pedal. It makes absolutely no attempt to start. The abs pump makes a noise just after the ignition goes on though.
I don't know what to do?? This kind of leaves me stumped as if I can't resolve this then I can't fit my new engine! If the 1.2 ran off the 1.4 then I'd be jammin'! I don't have access to MES, I definitely 100% fitted the 1.4 loom like for like
Thanks for any advice relating to this
Mark
Mark
