ultimatequinoxe
Being my first Fiat out of the 110 cars I've owned, I am still learning my way around my Stilo Abarth (03 plate sillyspeed).
I have a flappy sound on low rpm acceleration (eg when pulling off from stand still) - a classic manifold gasket leak sound I think. However I pulled the heat shielding off the exhaust manifold and cat but can see nothing because of whatever it is directly above (not sure yet if its the head or a separate thermostat housing etc). Anyone got any thoughts on how I can get to the manifold gasket to see if its leaking? Or is there a chance its the inlet manifold/gasket (though I'd expect running issues if that was the case, but one never knows)? Seems to be a common'ish problem so thought I'd check for any tips/pointers etc.
Plugged my 327 in yesterday and got:
P0707 - clutch switch - invalid signal
P1555 - - signal low
P0235 - Boost pressure sensor -
The clutch switch is above the brake pedal correct? But what about the boost pressure sensor?
Thanks for all thoughts and help!
Apart from these bits and a missing metal contact plate for my + gear paddle (annoying to have to replace the whole paddle just for the sake of a tiny piece of metal), everything else is going fine so far
