Driving home from a country park today the car bleeped up an engine fault and then temp sensor failure! As the temp gauge dropped to zero. A minute later the gauge started working again and the error went away but engine light stated on.
On testing when I got home, ecu scan is showing the stores error message. I also note with the engine off the message shows and the rad fan kicks on (presumably a built in feature).
Question is, where is the coolant temp sensor on a 1.2 stilo? I'll check the connections later when the engine has cooled down and I can be arsed looking!
Car has been great recently it's typical it develops a fault 4 days before its pressed into summer holiday use!
