is the egr blanked yet?
if not, get it blanked.
if you have just filled up with fuel - how much fuel? check the fuel lines at the back to the tank, I doubt there is a pump issue however.
Diagnostics are a must now, you need some real time data. ALso, in 1st/second gear hesitation, you absolutely sure the clutch is ok?
