Hi folks,
Ive an 2002 fiat stilo 1.6.... i have a problem with the car which is now becoming very frustrating!
It started with the engine light coming on whilst holding/maintaining revs over 3000rpm for say 20 seconds... then this happened more often on normal drives and lower down the rev range and also not requiring the 20 seconds but more like 4 seconds.
Then on idle the car started to hunt and stall.
The car then really started to become a pain...on pulling away the car around 1250rpm would hesitate and bog down..so the clutch had to be dipped and rode to keep the revs up...after the intial bogging down the revs would suddenly shoot up and it would drive normal. At this point on idle it would hunt...nearly stall, pick up again...repeating itself until it stalled completely.
Had the rac out....diagnostics said throttle body, track one. So bought a working 2nd hand throttle body and did the throttle learn...no change.
So i bought a working ecu (along with body computer and key as my central locking had stopped working a week before)... fitted all ok...but same happened.
Took it to a guy i know who has diagnostic equipment... we cleared the ecu of all fault codes....did the throttle learn...cleaned the fusebox next to the battery..checked each coil...spark plug and did a compresssion check... no problems...no fault codes.
Took it for a drive to see what fault codes would come up... none come up.
Once i had driven the car hard...the idle was fine and it pulled away better but was still bogging down at 1250rpm. Also if the revs were maintained at 3000rpm i could feel the car hesitating then clearing.
Other notes...went round a roundabout...problem of hesistation occured.
After getting back and engine turned off for 6/7min... on start up.. idle hunting and stalling bad again...and on pulling away very boggy..again! Engine temp was near enough half way and hadnt cooled much since the drive.
Put on diagnostics...no fault codes.
So...we are thinking fuel related..fuel pump??
Anyone have any clue? Thanks.
